adamhoud Posted April 1, 2009 Share Posted April 1, 2009 I have seen where some suggestions have been made to convert an existing l28 transplant to turbo instead of swapping the whole motor......if I already had an 83zxt and 73z with l28/t5 could I technically just swap the top end/turbo/EFI/harness to the 73? Do other fixes have to be made for it to work...oil lines etc? Thanks in advance...yes I searched Quote Link to comment Share on other sites More sharing options...
Challenger Posted April 2, 2009 Share Posted April 2, 2009 Turbo needs oil, knock sensor wont be there, was your head a n42 or n47? That would decide if you have dished pistons. Quote Link to comment Share on other sites More sharing options...
Xnke Posted April 2, 2009 Share Posted April 2, 2009 No, the fact that it's a '73 would determine that he has flat top pistons...heeeheeehee....Well, Most '73s. I've heard rumors that the '73 240Z's could have dished pistons as well, but I don't know. EDIT: i just re-read his post, and it seems he's already got an L28 installed...my bad... Quote Link to comment Share on other sites More sharing options...
adamhoud Posted April 2, 2009 Author Share Posted April 2, 2009 The head I have on my 83 is a P90, this is all hypothetical as I am considering buying a 73 240z with an L28/T5 swap already in it. Not sure what the block is though....N42 is the one to look for with dished pistons correct? Quote Link to comment Share on other sites More sharing options...
Challenger Posted April 3, 2009 Share Posted April 3, 2009 No, I need to know what head is on the 73's L28, your using it's bottom end and the 83's top end. I really dont see why you would not just swap the entire engine. The amount of work that youd put in to modifying the stock block and NA system for the turbo could easily been spent on just switching out the entire engine with less hassles. Quote Link to comment Share on other sites More sharing options...
adamhoud Posted April 3, 2009 Author Share Posted April 3, 2009 It would be due to having to rebuild the bottom end as well as the head on the 83, as opposed to just using the good condition 73 L28 bottom end as is, and some reworking of the 83 head. Quote Link to comment Share on other sites More sharing options...
S130Z Posted April 3, 2009 Share Posted April 3, 2009 Keep doing your research. It took me about 10 months of reading before I was completely ready for a turbo swap. If you said you searched and found nothing on this, then you didn't look hard enough. There is a lot more to it than what you are thinking. Trust me, I tried the NA block turbo transplant, and it is cheaper and more reliable to just pick up a turbo motor. If you do it right now, you won't have to do it right after you have done it wrong(That sounded a bit weird to me... oh well). Quote Link to comment Share on other sites More sharing options...
mikeith Posted April 12, 2009 Share Posted April 12, 2009 im interested in this aswell. i plan on building a turbo ls3 next summer but i just bought a 73 240 with a l28 that was built by john williams in atlanda georgia just a few years ago. i would like to convert it to an l28et to get me by until then but since i have a fresh bottom end i dont want to waste it. Quote Link to comment Share on other sites More sharing options...
