EDIS RPM Signal Unreliable
nienberg.11
First, let me give some background on my setup. I run MSnSE with EDIS. The car ran fine for weeks on this setup, but lately it's been stalling out unexpectedly or not starting. Whenever the car stalls, it starts back up after sitting for a few minutes.
After using a laptop to diagnose the stalling, I saw that the MS was losing the rpm signal from the EDIS module entirely and cutting fuel. I double checked the clearance of the VR sensor, and it's at .020" from the toothed wheel which is well within the normal range. I also checked for corrosion in the connectors at the coil pack, VR sensor, and EDIS module. They all checked out.
I'm almost stumped at this point. My only thought is that the VR sensor may be damaged. It was knocked around pretty hard when my toothed wheel broke loose from the crank pulley at one point due to poor welding.
Has anyone else had a similar experience? Do you have any insights as to what would cause this intermittent RPM signal?
Good thinking, z-ya. I sprayed the db37 out with brake cleaner and coated the pins in conductive grease. Unfortunately this wasn't the problem. I took the car for a drive and after 10 minutes it stalled. 3 minutes later, it started back up. Another 30 seconds and it was stalled again. 5 minutes after that it was back up. I headed toward home and started datalogging at that point. Right as I pulled into my space, it stalled again. I'm still thinking the VR sensor may be faulty somehow.
I've attached the datalog in case it might shed any light. The interesting portion is at the bottom where the rpms go to zero.
rpm cut-out.zip
Guest Rolling Parts
I bought used parts too. I had 1 EDIS module failure one week and then one of the coils on a coil pack go out the next week. There must have been some history why the donor car was in the junkyard.
You might put a timing light on the engine and see if you're getting spark when the car dies. The EDIS is independent and will throw a spark if its parts are OK. If it sparks, then you're EDIS is actually fine and you might have a PIP wire discontinuity OR the ECU itself may be having a problem...
Z-ya: I have had broken solder connections on the back of the db37 in the past. I'll take a look, but the fact that the signal comes and goes makes me think it's something else.
Rolling Parts: That's interesting. I had always heard that EDIS modules were nearly infallible. I don't have a timing light, but I had the same thought. I just built the diode circuit to run the 280z tach from the EDIS coils. When I get that installed, I can check to see if the tach still registers rpms as the car coasts to a stop after the MS cuts fuel. If so, the EDIS is still firing and I have a PIP/SAW connection issue. Otherwise it's the VR or the module.
Guest Rolling Parts
EDIS modules are "good" when new. Any electronic component from a salvaged yard has NO GUARANTEES (lots of Katrina/Rita hurricane seawater flooded cars ended up in the salvage yards).
Get a timing light. They are only $40 from Autozone and are a must to confirm real ignition timing.
Remove the tach diodes and wiring. That will remove one more unknown from the equation. Who knows if there is some cross talk or grounding when the diodes get warm.
Speaking of grounding, unground the capacitor on the coil pack(if it's installed on the +12 like in so many diagrams. You don't really need it anyway as far as I can tell and MegaJolt confirmed that on their site: http://www.autosportlabs.net/MJLJ_V3_vehicle_installation_guide
Rolling,
- The timing has already been checked with a timing light. I just don't own one.
- If you read my last post, the diode circuit can't be the issue since it isn't in the car yet.
- I read over that link, and it says that grounding the cap 'may be safely omitted.' There's nothing to suggest that having it grounded causes problems. I'm fairly certain my coil pack doesn't have that cap anyway.
Guest Rolling Parts
Timing lights are diagnostic tools, get one and TEST if you have spark on all plug wires. No sense in looking at anything else UNLESS you can confirm that the EDIS is throwing a spark on it's own. That is test #1 on an ignition problem. It's also a MUST with EDIS because you need to check to be sure that it's doing the advance you think you're getting (REAL important on a turbo!)
"There's nothing to suggest that having it grounded causes problems"
That's job #2 (especially if Job #1 shows no spark). Test the power and the grounds on the coil and that means confirming that there is no power leakage through the cap.
Sorry about not getting the time sequence on the diode install, I was still confused about using brake cleaner(which is a serious plastic solvent) and then coating all the DB connector pins with CONDUCTIVE grease. What I try to avoid is any cross-talk between pins on that connector...
I'm not sure what part of "the timing has already been checked" isn't getting through. Let me make myself perfectly clear. After installing EDIS, I used a timing light to verify that the actual advance matched what Megasquirt was showing. In my current situation, I could blow money on a timing light I don't need, or hook up my tachometer which I need to do anyway, to get the same diagnostic information.
As for cleaning my db37, I'll use whatever works. As long as you aren't concerned about the finish of plastic parts, brake cleaner is harmless to them. And yes, I use conductive grease on my electrical connections to prevent corrosion. If you layer some over the female side of the db37 and wipe away the excess, all of the pins get a small amount and cross talk isn't an issue.
Thanks for these redundant warnings. I know you're quite the MS/EDIS guru since you've had yours up and running for a whopping three weeks.
Guest Rolling Parts
Obviously SOMETHING HAS CHANGED on the car.
You suspect its ignition.
You refuse to re-check the ignition?
At least pull the plugs and crank it over and see if you're getting spark. That costs absolutely no money and will let you know what's wrong in the car (the ECU or the ignition system). Hopefully it is the ignition side since it's 100 times easier to diagnose than a build-your-own ECU and a tangle of wires.
Guest Rolling Parts
Actually, I (the non-EDIS guru) posted that one in your post.
Unless he's REALLY lucky, he'll have to start confirming some basics before jumping down to testing the sub-components. It's usually a waste to start at looking at everything in hopes of finding something. The first thing I'd do is to to find out which side of the firewall has the problem (ECU or ignition) and then work the problem from there. It's easy to get "stumped" if you work without tools and/or look in the wrong place.
Speaking of diagnostic tools, a VOM is a great tool to see if your EDIS is outputting a 12V PIP for the MS to pick up as RPM and/or if there is a shielding problem that's grounding out that signal before it gets to the MS.
Still sounds like an intermittent PIP connection somewhere.
Did you scope the PIP and SAW? If so, are the voltage levels correct? The PIP should be 12V, but it can operate below that. The SAW needs to be a minimum of 3V to control the EDIS timing. Else it will be stuck in limp home mode. Look at the signals for potential noise problems.
Pete
Thanks for the suggestions z-ya and softopz, I've figured it out.
I used the method I described earlier and ran my tach off of the negative side of the coils. I disconnected the fuel pump and verified that the tach would operate during cranking. It showed 200-300 rpm while cranking, matching the megasquirt.
Having done that, I hooked up the laptop, took the car for a drive and waited for it to stall. Once it did, I hit the starter and confirmed that not only was the MS getting no tach signal, the tach was showing no rise while cranking. Therefore, the coils were not firing and this was not a PIP/SAW communication issue between EDIS and the MS.
That meant that the problem was either in the VR sensor, the EDIS module, or the wiring between the two. The wiring checked out, so I replaced the VR sensor this morning. I've driven the car for about an hour total since then with no further stalls.
While having a timing light would have narrowed this problem down in the same way, I'm on a fixed budget and had the tach diode circuit ready to install. It made no sense to buy more equipment when I could use what I already had available to me. There was no reason to suspect that the timing had changed, as the car ran normally right up until each stall. Also, using this diode circuit instead of the tach output on the EDIS module will let me know instantly if I have spark or not when diagnosing future issues.
I knew it was something on the MS input side. Just happened to be the input to the EDIS module (VR sensor). Good job!
Pete
