Got coil packs (COP) With MS.
1 fast z
Well, I have always hated the spark plug wires going across the intake manifold and the valve cover. So I am running wasted spark with coil on plug setup. I am just using the ford EDIS 6 module to fire them.
Old System:
New System:
Also took it on a mountain drive to try it all out
Edited by 1 fast z
File Size
Looks good.
My only concern would be if the EDIS module dwell time was compatible with those coils. I guess only time will tell. If you are not missing at high RPM/boost levels, then the dwell is probably long enough, but you don't know of it is too long. This could shorten the life of the coils and or cause them to overheat.
To verify the dwell is correct you really need to measure the dwell time on a running engine that those coils came from, and compare it to the dwell of the EDIS module. The best way to do this is with a scope and current probe attached to the coil "-" terminal.
Pete
