Chemicalblue Posted April 20, 2009 Share Posted April 20, 2009 I need some help with figuring this out, here is the calc that I'm trying to use. http://forums.haltech.com/viewtopic.php?f=10&t=1880&p=7950&hilit=injection+firing+angle#p7950 I'm trying to set the "injector firing angle" map up on my ecu and I have no idea how to get the numbers to plug in. Quote Link to comment Share on other sites More sharing options...
PalmettoZ Posted April 20, 2009 Share Posted April 20, 2009 Hey- Do you have a baseline in which to start with on your ECU? I would assume so. Your injection angle I believe is the angle between firing pulses based on a 360 degree circle. For example hypothetically a 25 millisecond pulse could "pulse" at a 10 degree injection angle meaning it would fire 36 times for one engine revolution. Since every engine flows differently you would need to start with a baseline and a dyno and O2 sensor for feedback and keep doing runs to fine tune it. Hope this helps- Quote Link to comment Share on other sites More sharing options...
