gumby240 Posted April 21, 2009 Share Posted April 21, 2009 I have the MS2 with the V3.57 & 2.888 its in a 240Z with a 280ZX turbo motor using the '83 turbo dizzy & I am not getting spark or fuel pump prime or pressure. I have checked the pump & the wiring for the relay and for the pump & its good, so I think I just don't have something configured right. Any suggestions on what to try first ? I have read Moby's writeup and the manuals. Quote Link to comment Share on other sites More sharing options...
Matt Cramer Posted April 21, 2009 Share Posted April 21, 2009 Are you seeing RPM in MegaTune when you crank it? Quote Link to comment Share on other sites More sharing options...
dexter72 Posted April 23, 2009 Share Posted April 23, 2009 With the key turned on the fuel pump relay should click so check why that is not working right first. Quote Link to comment Share on other sites More sharing options...
softopz Posted April 24, 2009 Share Posted April 24, 2009 I remember when I first was wiring my ms in I had not set the code right so It wouldnt even get power to pump. Also if you have the boot jumpers on you MS wont give power to nothing. Quote Link to comment Share on other sites More sharing options...
gumby240 Posted April 24, 2009 Author Share Posted April 24, 2009 Matt Cramer said: Are you seeing RPM in MegaTune when you crank it? No RPM ! What have I done?...or not done? Quote Link to comment Share on other sites More sharing options...
Guest Rolling Parts Posted April 24, 2009 Share Posted April 24, 2009 Was the turbo engine with that ignition system running BEFORE the transplant? Quote Link to comment Share on other sites More sharing options...
gumby240 Posted April 24, 2009 Author Share Posted April 24, 2009 Engine yes, Distributor came out of a parts car i have,so i am not sure of its condition Quote Link to comment Share on other sites More sharing options...
Guest Rolling Parts Posted April 24, 2009 Share Posted April 24, 2009 There is an associated ignitor(transistor) that should be on the coil mounting bracket. There is an optical sensor in the distributor. You should have added the "pull-up" circuit run to the distributor. You could diagnose any of those... Quote Link to comment Share on other sites More sharing options...
gumby240 Posted April 24, 2009 Author Share Posted April 24, 2009 Rolling Parts said: There is an associated ignitor(transistor) that should be on the coil mounting bracket.There is an optical sensor in the distributor. You should have added the "pull-up" circuit run to the distributor. You could diagnose any of those... Well I bought it assembled from DIY & I know it has the coil driver installed so i didn't think i needed the ignitor is this correct? I am not sure i have it configured right as far as timing & trigger. Quote Link to comment Share on other sites More sharing options...
Guest Rolling Parts Posted April 24, 2009 Share Posted April 24, 2009 Sorry, I should have asked if you were using the VB921 (or BIP373) transistors or the stock Nissan driver. The V3.57 does not normally come with one installed. I guess that leaves the optical sensor in the dizzy and the pull up circuit for testing... Quote Link to comment Share on other sites More sharing options...
gumby240 Posted April 24, 2009 Author Share Posted April 24, 2009 Rolling Parts said: Sorry, I should have asked if you were using the VB921 (or BIP373) transistors or the stock Nissan driver. The V3.57 does not normally come with one installed. I guess that leaves the optical sensor in the dizzy and the pull up circuit for testing... Sorry but what is the pullup circuit? Quote Link to comment Share on other sites More sharing options...
Matt Cramer Posted April 24, 2009 Share Posted April 24, 2009 It's just a 1K resistor from the wire going to pin 24 to a 12 volt wire. Quote Link to comment Share on other sites More sharing options...
Guest Rolling Parts Posted April 24, 2009 Share Posted April 24, 2009 It connects POWER to the distributor tach line through a 1K resistor. Sorry, I thought you were referring to Moby's writeup (below): http://forums.hybridz.org/showthread.php?t=88246 Quote Link to comment Share on other sites More sharing options...
gumby240 Posted April 24, 2009 Author Share Posted April 24, 2009 yes i did wire it like moby's writeup but i have not had a chance to check for power there but i will when i get home after work. thanks for the help guys Quote Link to comment Share on other sites More sharing options...
gumby240 Posted April 25, 2009 Author Share Posted April 25, 2009 Yes there is power there. Quote Link to comment Share on other sites More sharing options...
gumby240 Posted April 26, 2009 Author Share Posted April 26, 2009 Ok so i really need some help here i have no spark & no fuel pump prime going on. I am pretty sure i have everything wired right but i am not sure i have everything configured right in mega tune, i am a newbie to computer stuff i have worked on many z cars and done a little tuning but some of this is over my head, am i in to deep? Quote Link to comment Share on other sites More sharing options...
softopz Posted April 27, 2009 Share Posted April 27, 2009 Did you load the code? If so try re flashing remember to REMOVE jumper on ms board. Usually the wierdest problems are caused by bad code flash. What msq are you using maybe you should attach so people can assist you more. Check your power to your MS and fuel pump see if gets 12v + power in switch and RUN. Cause you have power at distributor wire but thats a different wire. Quote Link to comment Share on other sites More sharing options...
Matt Cramer Posted April 27, 2009 Share Posted April 27, 2009 You'll need to get the RPM input working. Nothing else will work until that happens. Can you see an RPM signal on a Stimulator? Quote Link to comment Share on other sites More sharing options...
gumby240 Posted April 27, 2009 Author Share Posted April 27, 2009 Yes i was getting RPM on the stim, i am guessing i don't have something set up right when i did the general setup & configuring Quote Link to comment Share on other sites More sharing options...
Matt Cramer Posted April 28, 2009 Share Posted April 28, 2009 If it still gets RPM on the Stim, it's likely to be a wiring issue. Missing pull up, maybe? Quote Link to comment Share on other sites More sharing options...
