Challenger Posted April 22, 2009 Share Posted April 22, 2009 Im working on a program for C for engineers. Its not an assignment just trying to practice some and get used to variables, printing, taking user imput, doing calculations, etc. Im making a simple program to calculate what it costs to fill n tanks of radius r and height h with a certain material. Gravel, water, wheat or asphalt... all I could think of. I then have prices for each of these per unit of volume so it will show how much it costs to fill the tanks. But Im having some issues getting it to work. ----------------------------- #include int main() { double radius; double height; double quantity; double area; double volume; int material; double unit_cost; double total_cost; printf("nWhat is the radius of your storage tank?n"); scanf("%1f", &radius); printf("What is the height of your storage tank?n"); scanf("%1f", &height); printf("How many tanks would you like to build?n"); scanf("%1f", &quantity); area = 3.14 * radius * radius; volume = area * height * quantity; printf("What would you like to store in these containers?n1) Graveln2) Watern3) Wheatn4) Asphaltn"); scanf("%d", &material); if (1 == material) { unit_cost = 1.56; } if (2 == material) { unit_cost = .65; } if (3 == material) { unit_cost = 3.24; } if (4 == material) { unit_cost = 4.11; } total_cost = volume * unit_cost; printf("nIt will cost you %f dollars to fill up all your tanks with the nmaterial you selected.", total_cost); return 0; } -------------------------- Can anyone give me an tips on what to change or if there is anything really obvious? It seems to not even recognize values you put in for the radius and height... Thanks BTW, Im using DevC++ as my compiler. Quote Link to comment Share on other sites More sharing options...
h4nsm0l3m4n Posted April 22, 2009 Share Posted April 22, 2009 Its been a while since I've delved into C, I use VB mostly. Try changing the f in this line scanf("%1f", &radius); to lf (for long float) and see if it works. I think a double is classified as a lf for some odd reason. If it works, you can change the rest of it similarly Quote Link to comment Share on other sites More sharing options...
Challenger Posted April 22, 2009 Author Share Posted April 22, 2009 Ok thanks, Ill try that. I ended up changing the doubles of radius, height and quantity to int. It works that way but Id like to be able to type in 3.4 instead of just 3 for the radius or height. Quote Link to comment Share on other sites More sharing options...
Hyuri Posted April 22, 2009 Share Posted April 22, 2009 It is, indeed, related to the type specifier (%f for floats, %lf for doubles, %Lf if you want to get crazy and use long doubles) in your scanf calls. Different types, even of the same variety (e.g. floating point), can be stored in wildly different internal formats. If you're really going to use C++, try using STL methods like cin and cout. They make things much simpler - not having to remember the format specifier for each type you want to use is incredibly helpful. The basic library is also usually , not (canonically in C++, FYI). switch is also generally better than a sequence of if blocks, for exclusive selection off the same variable. There are some circumstances where nested if blocks are better for performance, but it can be rather tricky for generally minimal gain. Quote Link to comment Share on other sites More sharing options...
wheelman Posted April 22, 2009 Share Posted April 22, 2009 Another question to ask is why you decided to use doubles instead of floats. The float type has more than enough precision and range to handle the values you're dealing with and uses less memory. It's also just a style thing but it's much easier to read code where the variable being tested is on the left side of the == and the value on the right, like this (material == 2). Hyuri is correct about it being easier to use the standard C++ IO library (once you figure out the syntax) and scanf is a function I avoid like the plague, it has all sorts of issues. I've been programming in C/C++ for over 25 years and haven't used it for the last 20 of them. You can also calculate the square of a value using this symbol ^. Your area calculation statement then becomes area = 3.14 * radius^2; Quote Link to comment Share on other sites More sharing options...
thehelix112 Posted April 22, 2009 Share Posted April 22, 2009 #include #include // for decl of M_PI using namespace std; int main() { double radius= 0.0; double height= 0.0; double quantity= 0.0; double area= 0.0; double volume= 0.0; int material= 0; double unit_cost= 0.0; double total_cost= 0.0; cout << endl << "What is the radius of your storage tank? "; cin >> radius; cout << endl << "What is the height of your storage tank? "; cin >> height; cout << endl << "How many tanks would you like to build? "; cin >> quantity; area = M_PI * pow(radius, 2); volume = area * height * quantity; cout << endl << "What would you like to store in these containers?n1) Graveln2) Watern3) Wheatn4) Asphaltn ? "; cin >> material; switch(material){ case 1: unit_cost = 1.56; break; case 2: unit_cost = .65; break; case 3: unit_cost = 3.24; break; case 4: unit_cost = 4.11; break; } total_cost = volume * unit_cost; cout << endl << "It will cost you " << total_cost << " dollars to fill up all your tanks with the material you selected." << endl; return 0; } Also ^ is the bitwise xor operator, and does not do power-of operations. Dave Quote Link to comment Share on other sites More sharing options...
Challenger Posted April 22, 2009 Author Share Posted April 22, 2009 Ok I ended up figureing out the pow(radius,2) with the help of a friend at school (CS major). It seems to work fine now for any value. #include #include int main() { double radius; double height; int quantity; double area; double volume; int material; double unit_cost; double total_cost; printf("nWhat is the radius of your storage tank?n"); scanf("%lf", &radius); printf("What is the height of your storage tank?n"); scanf("%lf", &height); printf("How many tanks would you like to build?n"); scanf("%ld", &quantity); area = 3.14 * pow(radius,2); volume = area * height * quantity; printf("What would you like to store in these tanks?n1) Graveln2) Watern3) Wheatn4) Asphaltn"); scanf("%d", &material); if (1 == material) { unit_cost = 1.56; } if (2 == material) { unit_cost = .65; } if (3 == material) { unit_cost = 3.24; } if (4 == material) { unit_cost = 4.11; } total_cost = volume * unit_cost; printf("nIt will cost you $%.2f to fill up all your tanks with the nmaterial you selected.n", total_cost); return 0; } Quote Link to comment Share on other sites More sharing options...
wheelman Posted April 23, 2009 Share Posted April 23, 2009 Also ^ is the bitwise xor operator, and does not do power-of operations. Dave Boy do I look stupid now!!! Dave is completely right. I guess that's what happens when you switch back forth between several languages. Quote Link to comment Share on other sites More sharing options...
Hyuri Posted April 23, 2009 Share Posted April 23, 2009 Okay, if you're going to use , printf, and scanf, why not just go back to C? You're using a C++ compiler, but you're writing C code. Also, using pow() to square adds the overhead of a function call (and the overhead of the math library!) without any real readability benefit. And M_PI, while common, is not a standard definition. And heck, wheelman, most of my experience over the last few years has been C#! Quote Link to comment Share on other sites More sharing options...
thehelix112 Posted April 23, 2009 Share Posted April 23, 2009 Hyuri, I think any decent compiler will inline a single function call to a library, so there is no overhead. The readability benefit I agree is non-existent though. Dave Quote Link to comment Share on other sites More sharing options...
Hyuri Posted April 23, 2009 Share Posted April 23, 2009 Hyuri, I think any decent compiler will inline a single function call to a library, so there is no overhead. The readability benefit I agree is non-existent though. Dave Yeah, but how many ... other-than-decent compilers are still floating around, still being used, still being written? Besides, it's just a bad habit to get into, assuming that the compiler will fix any performance hits your coding might induce. Better to code for performance in the first place if possible. Quote Link to comment Share on other sites More sharing options...
thehelix112 Posted April 23, 2009 Share Posted April 23, 2009 I'd hope noone is using other than decent compilers. I agree with you its better to code for performance, but performance isn't the only constraint as I'm sure you'll agree: Code maintainability, readability are also important. I don't think its incorrect to make code more readable if you know there is no performance hit with the compiler you're using. I more put in the call to pow() as an alternative way to get the power-of (^) functionaly previously talked about. Talking shop on hbz makes me feel wierd. Dave Quote Link to comment Share on other sites More sharing options...
wheelman Posted April 23, 2009 Share Posted April 23, 2009 Talking shop on hbz makes me feel wierd. Dave It creates micro black holes that will eventually destroy the universe so we better stop now!!!! Quote Link to comment Share on other sites More sharing options...
Challenger Posted April 29, 2009 Author Share Posted April 29, 2009 Ive got another one for you guys. Heres the code. #include #include #include int main() { double total; double prevtotal; int a; int b; int c; int p; a = 1; b = 6; p = 0; c = rand(); srand(time(0)); total = prevtotal = 0; while (a < 99999999 && b < 99999999) { total = c * pow( sin((a % * (a % ), 2); printf("%.0lf", total); a = a + 1; b = b + 1; if (total < prevtotal) //printf("nnnnnnn"); prevtotal = total; } return 0; Dont mind the part concerning the total and prevtotal. We were just trying to find when it switched from positive to negative in an earlier version of the program. Is there anyway to make this a screen saver? It goes on for quite a long time and if needed it could be looped so it repeats. Also with my green font in the command prompt it looks like the matrix! I think this would be an awesome screen saver, and its easily modified so it only displays ones and zeros so it looks like binary code... All you have to do in this case is remove the C variable from the equation for the total. Quote Link to comment Share on other sites More sharing options...
