Crazy backfire issue!
jacob80
Hey guys, we have MS1 V3 board with MSnS. We're trying to tune our L28ET but are having a little issue. Under load, at about ten miles an hour, the RPMs are good but once you trying to start accelerating at all it goes way lean and sound like it cuts the fuel or something, pauses, back fires, then comes back. Could this be caused by our pulse width? We are literally going from ~14 AFR to like 8 within 100 RPM increase. If anyone could suggest anything, it would greatly appreciated. Thank you!
Ok so our distributor shaft was off, which we fixed, and seemed to help nothing. Here is the issue:
The car revs to 6500 rpm easily while not under load. First gear, just engaging the clutch, going about 10 mph and slowly climbing RPMS, 1000, 1500, 2000, 2500, all the sudden, the car seems to have no throttle response and seems to almost die, and a backfire immediately follows if you don't take your foot off the gas. The AFR shoots through the roof for a moment and then comes back down. Now, back down to 1000rpm. What is our issue? Is it something with the injectors? We have 42 lbs.hr Bosch 400s running PWM. Could comething with the PWM be causing something like this? Any help here is greatly appreciated, the car sounds GREAT, but doesn't like to go over 3000rpm.
You said in the first post that the car goes lean during acceleration, but you said the AFR goes to 8 which is rich. Would you clarify if the car goes rich or lean under acceleration, that will make all the difference on what could possibly be wrong. If the car is going lean it could be a bad fuel pressure regulator. I had a bad one and the car would rev in neutral fine, but at about 3000 rpm when boost would just start to build it would fall flat and run out of fuel.
Ok, hold the phone! I believe it is our fuel pressure regulator. It is a megan racing RRFPR, which I believe is our whole problem. I think that we've been setting our fuel pressure around 40 at idle and when under load, accelerating, it is increasing fuel pressure in excess and dumping in more fuel than needed and creating a rich mixture. Yea, i meant rich, I only said lean because the AFR gauge would go lean AFTER the event, so it wasn't ever lean. We're about to find out if that was our problem. Should we even attach the vacuum line or can we just run the fuel pressure regulator at a set PSI and let the computer adjust the fuel flow through the injectors?? Thanks everyone!
Ok, I take back what I said, sorry. Went for a test run and the FPR seemed to have no effect on our problem. The datalogging is showing when reaching ~2300 RPM from a slow, slow climb in first gear, it completely falls on its face , a slow pause, then followed by a backfire out the downpipe. We are running 440cc injectors with pulse width modulation, could this be a factor at all with the stock turbo? I'm sure the size isn't the issue but maybe the pulse width and/or duty cycle? Here is a pic of the datalogging where the event occurs:
Any help would be appreciated, hopefully we can get a response tonight and see what we can do, thanks guys!
Stock rebuilt long block L28ET
Stock T3 turbo
MSA downpipe
Performance products front pulley
Fidanza Flywheel
Bosch 440cc 42lb/hr injectors (using PWM on megasquirt)
Throttle body space with 240sx throttle body
Front mount intercooler
Megan Racing RRFRP
Pallnet fuel rail
Walbro 255 lph fuel pump
MSnS (v3 board, IGBT triggering enabled) with relay board
Upgraded Alternator (280zx turbo alternator) with MSA wiring harness plug
Did you setup the WBO2 right?
I don't know if it has changed, but before you had to reprogram an LC-1 (I think 0v=10:1, 5v=20:1 AFR, which is NOT default by Innovate), then setup MegaLogViewer to Innovate 0-5v.
This setup does not register anything lower then 10:1 AFR.
  jacob80 said:
Uhhhh.....ok? I know that, can you help me resolve this issue?
I apologize if I sounded like a smart-ass, but I hoped you'd be able to either re-evaluate your situation if you meant what you wrote or notice the typo and correct it so the resident ms experts (aka not me) would be able to help you more effectively.
Either way, it was meant to be helpful. Sorry if you don't feel that way.
Best wishes in resolving the issue.
slown280z -- I helped Jacob reprogram his LC-1 prior to this run (and log), which was required as one of the analog inputs (the one feeding megasquirt) had been set as a narrowband output. All is good there now, and it is logging nicely to the file. After the change the cockpit gauge agrees with what the megasquirt is reporting now.
Thanks!
I looked over the msq file and I only see a couple general things. One I am not sure if it is real or just didn't load correctly when I opened you msq, but the setting for overboost rev limit was 0 kpa which is not valid, it should be something like 200kpa or were you want spark cut on too high of boost.
These probably don't have any impact but just observations: the spark angle is low for idle for an L28ET, you have 15 it is more like 23 on the stock setup. The fuel table only has a couple bins beow 100kpa. You will probably want something like 20,40,60,80,100 etc or you will have a lot of trouble trying to tune for cruising which is were you spend most of the time driving on the street. Maybe this is causing too big of a jump and causing some of the problems with it going rich, I am not sure.
I don't think that we set up the overboost limit, so I assumed that 0 disabled that function as in many other places in megatune. Do you think that this might be the root cause -- spark being cut right out of the gate and fuel being dumped into the exhaust, then ignited once the spark resumes?
