O2 Sensor 3 pin Where to pins go to ECU
RUZN
OK I did a ECU swap into my 280zxt Now I switched to the 3pin O2sensor.
Black goes to Pin 24
One other wire goes to PIN 34 or Power from VCM
now where does the other wire go? Pin 16?
Whenyou test O2 sensor it says to remove Pin 16 thus im thinking it goes there cause you test ground from Pin 24 SOOOOO
I had it liek this
Ground (Pin 24 liek the 280zxt)
Heater element #1 to Pin 34 (power from VCM)
Heater element #2 to Pin 15 (cause I read the Diagram wrong. *I get all screwey Volt readings from pin 15 so im guessing thats wrong and when I further look at it it looks to actually be on PIN 16
Can anyone verify if the #2 heater element Pin is just to body ground (or ecu ground) or Pin 16 (which looks to be a ECU ground)
Edited by RUZN
put in wrong pin number
I was hoping i could just get the easy answer lol I guess mine is actua;ly in pin:24 blackpin:34 power vcm for heater filamentpin:115 not sure what 115 is though... just wondering if anyone knew exact pins to go into ty though
