Blobber Posted May 13, 2009 Share Posted May 13, 2009 I have a slight problem with my L28+NA tranny swap. Engine package fits perfectly, but the transmissions shifter doesn't come to the right location. Engine and transmission came from 280zx and the tranny is 5-speed version. After thorough search and reading here I thought that this package would fit perfectly. But not a chance... The body which I'm putting the engine is early 260z. What seems to the problem or have I missed something totally? Previously car had L26 with automatic. Also before installing I measured length from middle of engine mounts to end gearbox and compared it to the old one(L26+automatic), and that was same length. I'm bit confused... BTW. I wasn't sure which section to post this to, but if there is a problem with it, could moderators move this to right section? Quote Link to comment Share on other sites More sharing options...
evildky Posted May 13, 2009 Share Posted May 13, 2009 this si a common issue, you can clearance the metal or use alayback shifter, I've even seen one shifter that was cut and offset for clearance Quote Link to comment Share on other sites More sharing options...
