dhartig Posted May 23, 2009 Share Posted May 23, 2009 I am mocking up my TT system on an old block and head so I can pre-buy the appropriate lines and connections for a fast install later. I think I have all the connections to the intake log and the carb correct, but please let me know if any of you see something amiss. Where I am getting lost is the connections that are open to the air/fuel stream in the casting that supports the carb. There a three lines coming in, one on each open side. Can someone in the know let me know what connections are made to these openings? I can see one for NOS, but I am not sure of the others. Thanks Quote Link to comment Share on other sites More sharing options...
Tony D Posted May 25, 2009 Share Posted May 25, 2009 PCV, NOS, and Brake Booster Vaccum Source. Usually there are two more, that aren't in the plenum, but in a separate chamber beneath it, and that is for your bypass water supply from the thermostat base through those two lines and thence to the water pump inlet---it helps with cold weather drivability and in humid climates keeps the bottom of the plenum from turning into one huge ball of ice (icing!). Hope that helped. Quote Link to comment Share on other sites More sharing options...
dhartig Posted May 25, 2009 Author Share Posted May 25, 2009 Thanx Tony D. That clears it up. Now to pick up a progressive injection system, and an AFR gauge. Quote Link to comment Share on other sites More sharing options...
Tony D Posted May 25, 2009 Share Posted May 25, 2009 Don't forget to use the PCV valve off a Nissan! It has flow characterisitics that give some strange evacuation flow rates. You would think at idle it would suck like crazy, and at WOT (low vacuum) it would close up and become inefficient...but it really does work well (uses a tapered spool through an orifice internally to control flow rates almost contrary to what you would think based on volume and vaccum present!) Quote Link to comment Share on other sites More sharing options...
