N/A dizzy wiring
GOTHALOSISM
I know this has been covered at least once but i have been searching for a while now and my eyes hurt.
Long story short I fried my turbo Dizzy and now I need to use a N/A dizzy with using fuel only from MS. So once I swap out the dizzies how do I wire them up using MS 1 3.57 board? The newer dizzy is out of a 82 n/a with the vaccuum advance on it.
Fuel only would mean you're triggering off coil negative, correct? If so, your MS wiring will not change at all.
If I've misunderstood, and you're running MS off the inner workings of the dizzy, then the red wire inside the dizzy goes to the shielded ignition wire, the green wire attaches to the outer shielding.
