Gauges
I'm pretty sure the 7812 needs at least 15 or 18 volts coming in to get 12v coming out. That makes it pretty useless for automotive use. Maxim makes alot of regulator / dc-dc converter chips though, and they will usually send out a free sample or two if you ask for it. I would think if you got a regulator that would handle a moderate amount of current, you could probably run all of your autometer guages directly off of it.
FWIW, the dropout on a 7812 is 2.5V, so you could regulate 12V from 14.5 or higher, which is close to charging voltage.
http://www.national.com/ds/LM/LM341.pdf
I'm not sure you will get much more accuracy out of the gauges, especially since automotive regulators seem fairly good - it seems the only time I see voltage drop much is with lights and wipers on. You can fine tune the sensors with a small resistor wired in series, but I would think the gauges are intended to be used with a supply voltage of 14V-15V.
