streeteg Posted June 14, 2009 Share Posted June 14, 2009 So I got my mustache bar for my r200 swap--- but it looks like the bushings could use a sprucing up--- aka new bushings....where can these be had? Quote Link to comment Share on other sites More sharing options...
Huy350Z Posted June 15, 2009 Share Posted June 15, 2009 You can purchase urethane mustache bar bushings from MSA for less than $40: http://www.thezstore.com/page/TZS/PROD/PSDC06D/23-4139 You need to remove the original rubber to install it. The best way is to burn it out. So I got my mustache bar for my r200 swap--- but it looks like the bushings could use a sprucing up--- aka new bushings....where can these be had? Quote Link to comment Share on other sites More sharing options...
Savage42 Posted June 15, 2009 Share Posted June 15, 2009 You need to remove the original rubber to install it. The best way is to burn it out. ........and make sure you leave the sleeve in the bar!!! Quote Link to comment Share on other sites More sharing options...
misterZ Posted June 15, 2009 Share Posted June 15, 2009 You can purchase urethane mustache bar bushings from MSA for less than $40:http://www.thezstore.com/page/TZS/PROD/PSDC06D/23-4139 You need to remove the original rubber to install it. The best way is to burn it out. Yes, if in doubt, call them and they will explain but you must burn them out and leave the sleeve or you may not get them back in. Quote Link to comment Share on other sites More sharing options...
