beebeecivic Posted June 16, 2009 Share Posted June 16, 2009 Hey guys I was wondering if there is a Z grounding Diagram (a diagram showing all / most grounds) It would be nice since these cars have a lot of issue with grounding. thanks! -bee Quote Link to comment Share on other sites More sharing options...
dan5138 Posted June 16, 2009 Share Posted June 16, 2009 If you do a bit of searching you can find a factory service manuals (on this site) for most Z's with a full car schematic.Then you can then trace out all the grounds, and be certain it's acurate. Quote Link to comment Share on other sites More sharing options...
Oddjob Posted June 21, 2009 Share Posted June 21, 2009 This may be of some help to you if you are trying to run down and fix grounding problems in the Z. This is how I handled it: http://forums.hybridz.org/showthread.php?t=147928 Scroll down to Post #15. I'm not certain an electrical diagram will be much help to you because of the way grounds are done in most cars, including the Z. The post above explains why. Quote Link to comment Share on other sites More sharing options...
beebeecivic Posted June 22, 2009 Author Share Posted June 22, 2009 This may be of some help to you if you are trying to run down and fix grounding problems in the Z. This is how I handled it: http://forums.hybridz.org/showthread.php?t=147928 Scroll down to Post #15. I'm not certain an electrical diagram will be much help to you because of the way grounds are done in most cars, including the Z. The post above explains why. Thanks oddjob ill take a good long look Quote Link to comment Share on other sites More sharing options...
