beebeecivic Posted June 27, 2009 Share Posted June 27, 2009 Alright I have seen Pallnet and Atlantic Z's Fusible Link upgrades but i was wondering if this will work http://www.amazon.com/Stinger-Gauge-Fused-Distribution-Block/dp/B001IQIW7I/ref=sr_1_9?ie=UTF8&s=electronics&qid=1246072869&sr=1-9 I understand that there Stinger S4HDMAX is one that works , but i jus want to be open to more options. Thanks! Quote Link to comment Share on other sites More sharing options...
zfreak77 Posted June 27, 2009 Share Posted June 27, 2009 yep, That will work. If you dont wont to order it you could just go to your local car audio shop and buy one. It may even be cheaper. I bought one from a local shop named nortons car audio thats almost the excact same thing. Just buy the block, you don't need the fancy gold colored allen wrench that comes with some of the others and that they charge ten dollars more for. Buy they fuses from autozone or advanced and a battery cable and youv'e spent 43 dollars and some change. Good luck with the upgrade, Its simple. Quote Link to comment Share on other sites More sharing options...
beebeecivic Posted June 28, 2009 Author Share Posted June 28, 2009 yep, That will work. If you dont wont to order it you could just go to your local car audio shop and buy one. It may even be cheaper. I bought one from a local shop named nortons car audio thats almost the excact same thing. Just buy the block, you don't need the fancy gold colored allen wrench that comes with some of the others and that they charge ten dollars more for. Buy they fuses from autozone or advanced and a battery cable and youv'e spent 43 dollars and some change. Good luck with the upgrade, Its simple. hey zfreak thanks a lot for the encouragement I will get on it on monday Quote Link to comment Share on other sites More sharing options...
Oddjob Posted June 28, 2009 Share Posted June 28, 2009 Here's the one I used: http://www.crutchfield.com/p_211FBXS024/StreetWires-FBXS024.html?tp=3001 It's a bit more expensive than yours, but takes up to 125A fuses, and uses #1/0 cable in/out and #4 on the circuits. Quote Link to comment Share on other sites More sharing options...
