jerryb Posted June 28, 2009 Share Posted June 28, 2009 Does anyone know where I can get the male and female ECU connectors to make a patch harness. I found this outfit http://www.autosportwiring.com/Products.htm But find the prices a bit steep, so maybe I can make my own?? Quote Link to comment Share on other sites More sharing options...
Careless Posted June 28, 2009 Share Posted June 28, 2009 jerryb said: Does anyone know where I can get the male and female ECU connectors to make a patch harness. I found this outfit http://www.autosportwiring.com/Products.htm But find the prices a bit steep, so maybe I can make my own?? if it's for an RB20 you'll have a tough time making your own as you would need to find a junkyard car with the ECU and harness and purchase the ecu and cut the harness and take both home with you, then desolder the connector from the ECU. Quote Link to comment Share on other sites More sharing options...
jerryb Posted June 29, 2009 Author Share Posted June 29, 2009 As a matter of fact I have exactly what you describe. Is that all they do.....?!?!?! Careless said: if it's for an RB20 you'll have a tough time making your own as you would need to find a junkyard car with the ECU and harness and purchase the ecu and cut the harness and take both home with you, then desolder the connector from the ECU. Quote Link to comment Share on other sites More sharing options...
Careless Posted June 29, 2009 Share Posted June 29, 2009 I'm pretty sure, as I've had a friend make one or two patch connectors for SR20's. sometimes the pins are really stubborn. and I believe there's a place to get the pins that you can crimp on too, instead of soldering janky wires onto small pins that would be on the motherboard as a solid connection. that's not ideal in my opinion. Quote Link to comment Share on other sites More sharing options...
