GrenadeZ Posted June 28, 2009 Share Posted June 28, 2009 1972 240z factory 4spd. Has allot of difficulty going into first gear, almost all my weight is required. For reverse, I have to turn the car off and then slip it in otherwise it grinds like crazy. Im a newb with transmissions so this is a learning experience. Im thinking of changing the transmission fluid. Is it possible the clutch is bad or needs to be changed. *Possible related, I have a vacuum leak at the manifold of my 4bbl swap that is recent but im not sure if its related, ill plug it up and see if It helps.* Quote Link to comment Share on other sites More sharing options...
GrenadeZ Posted June 28, 2009 Author Share Posted June 28, 2009 Ok from massive amounts of headache inducing reading. I have deduced that it may be a linkage issue or that the clutch is not fully engaging. Well Im not sure how to fix either of those things does anyone have a link to a linkage adjustment? I let a friend borrow my hanes manual!! The good news is, I have a fresh 5spd and r200 at home, bad news is homes is 2 hours away. Quote Link to comment Share on other sites More sharing options...
GrenadeZ Posted June 28, 2009 Author Share Posted June 28, 2009 http://forums.hybridz.org/showthread.php?t=149456&highlight=clutch+linkage Could this be the issue? Ill investigate further... Quote Link to comment Share on other sites More sharing options...
Sam280Z Posted June 29, 2009 Share Posted June 29, 2009 Thunder, Sounds like the clutch is not fully disengaging. This is most likely either a clutch master cylinder or clutch slave cylinder problem. If I had to put money on it I would say it was the slave. You need to start by bleeding the clutch fluid out of slave cylinder. Change out all of the fluid so that you get no air bubbles while you are bleeding while repacing the fluid in the master. Another possibility - but less likely - is that the clutch disc has rusted to the splines on the transmission input shaft. If this is the case, the transmission will have to be removed. If it goes into gear while the engine is off, it is not a transmission problem. Stop forcing it, or you will create one. Sam Quote Link to comment Share on other sites More sharing options...
GrenadeZ Posted June 29, 2009 Author Share Posted June 29, 2009 thanks sam, actually I traced it down to a leak near the linkage. Im going to bleed the system and replace the slave this weekend. I dont think its rust because the car is my dd. Thanks for the input man! Quote Link to comment Share on other sites More sharing options...
cygnusx1 Posted June 29, 2009 Share Posted June 29, 2009 Try some ex-lax. Quote Link to comment Share on other sites More sharing options...
GrenadeZ Posted June 30, 2009 Author Share Posted June 30, 2009 lmao Quote Link to comment Share on other sites More sharing options...
