Mikelly Posted April 17, 2000 Share Posted April 17, 2000 My starter is dragging now when I start the car up... is this inherrant of relocating a solenoid??? Anything I can do to fix it? It hangs for a brief moment upon startup and then its fine... Mike ------------------ "I will not be a spectator in the sport of life!" mjk Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted April 17, 2000 Share Posted April 17, 2000 Nope, it shouldn't cause any sticking. Sounds like a problem with the ign switch? ------------------ Big Ed '82 280ZX Trubo, stock I think? Quote Link to comment Share on other sites More sharing options...
Mikelly Posted April 17, 2000 Author Share Posted April 17, 2000 Well I noticed it both with a remote starter trigger, and with the starter button on my Moroso toggle box... Mike ------------------ "I will not be a spectator in the sport of life!" mjk Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted April 17, 2000 Share Posted April 17, 2000 To be honest, I'm not sure I exactly understand what a remote solenoid is, but for what it's worth: When I went V8, I had lots of problems with the starter. I ended up solving it by fitting a starter relay. Are you sure you've got a good clean feed to the solenoid on the trigger side? The std. Datsun electrics are not that flash... Quote Link to comment Share on other sites More sharing options...
Mikelly Posted April 18, 2000 Author Share Posted April 18, 2000 Nope, I haven't removed the starter since I started having trouble and bought the new remote solenoid sold by summit. The starter wasn't dragging before I wired in the new remote solenoid, and FYI I don't have any factory wiring in this car. Re-wired it all back a few years ago... The shim isn't the issue either, but it must have something to do with the wiring on the hot side of the solenoid... I'll try that... ------------------ "I will not be a spectator in the sport of life!" mjk Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted April 18, 2000 Share Posted April 18, 2000 hummmmm... could you possible have left off a shim or two when you put the starter back on last? I'd check the shim just in case, how do the teeth look on the flex plate? ------------------ Big Ed '82 280ZX Trubo, stock I think? Quote Link to comment Share on other sites More sharing options...
Ray Posted April 19, 2000 Share Posted April 19, 2000 Do you have a ground wire from the block to the battery or the chassis????? Quote Link to comment Share on other sites More sharing options...
Mikelly Posted April 19, 2000 Author Share Posted April 19, 2000 I have a ground to the frame from the battery (2 actually) and a ground (3 actually) from multiple points on the engine, including the starter bolts, to the chassis. All are 0/1 gauge or better... Mike ------------------ "I will not be a spectator in the sport of life!" mjk Quote Link to comment Share on other sites More sharing options...
