Ron240zxt Posted October 6, 2001 Share Posted October 6, 2001 Hello all, well got the car to run better tonight, BUT!!!! im not happy, more depressed then anything. The car runs with a slight miss from idle to 3000rpm. My Fuel ration is 14.7 on a wide band o2, so looking good there. the plugs look nice and brownish, just doesnt sound right... There is also a poping noise every so offen almost non smooth pulses. the car initial timing is 22 degrees. Any Advice or help into determining what i need to do to correct this Please let me know...or any ideas what the noise is...Thank you Ron..... 38lb base fuel pressure 89-91 Rx7 injectors (550cc) L-28T with 87mm bore with 240 Rods p90 head Quote Link to comment Share on other sites More sharing options...
randy 77zt Posted October 6, 2001 Share Posted October 6, 2001 i havent tuned an sdsunit but i will guess-what is timing at 3000 rpm with no boost-should be about 32 to 36 btdc.14.7 is ideal but alot of engines wont run this lean-it depends on combustion chamber design.go a little rich then lean out.22 is a little advanced for idle even though oem zxt ecm ran at 20 btdc.i would probably try about 15.tune off boost first.after engine gets about 5 psi boost timing should retard to 22 to 24 degrees.try tuning for power then lean out at rpm ranges you use for cruise speeds. Quote Link to comment Share on other sites More sharing options...
Scottie-GNZ Posted October 10, 2001 Share Posted October 10, 2001 Ron, did you get my email? Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted October 11, 2001 Share Posted October 11, 2001 I'd check that ignition curve. I had the same problem for a while an it was due to too much advance coming in too soon. Every engine combo is different, but right now I have my RPM/IGNITION set as follows: 500 10 750 14 1000 16 1250 18 1750 20 2000 22 2250 24 2500 26 2750 28 3000 30 then 31 degrees from there. Then on the MAP/IGNITION screen I loaded a value of 250 from -14.5 to -18 to give me 5 degrees of "vacuum advance" at cruise and a value of 4 from +.33 to -8 to pull some timing out at high load. Also go back and check the magnet position. I found that mine had moved a few degrees after I did a minor adjustment to the pickup. Quote Link to comment Share on other sites More sharing options...
Ron240zxt Posted October 11, 2001 Author Share Posted October 11, 2001 Thanks for the help, but my complete coil packs burned down and no longer usable..the box that houses the coil packs are distroyed What could of caused it. If thinks couldnt get worse....Any idea what i can do? Thanks, totally depressed Ron Quote Link to comment Share on other sites More sharing options...
Mike C Posted October 11, 2001 Share Posted October 11, 2001 Check for a bad plug. If it has an internal failure and the spark cannot clear the gap, it can fire into the coil pack. (Easiest path to ground) Other than that not sure. Quote Link to comment Share on other sites More sharing options...
