280zex Posted July 10, 2009 Share Posted July 10, 2009 I met a guy and his wife at a hotrod shop in Federalway(South of Seattle) this weekend. He just purchased a 1976 280z with a 350/350 automatic swap for 3500.00. the car also came with a 11.9 1/4 mile time slip:burnout:. He's new to all of this so I'm gona get him set up here on this board. I have had z's for a long time and told him I can help with his new Z car project. I'm gona post some pix later this weekend. I did notice that from what I could see the motor mounts have only 1 bolt to the cross member. this doesn't seem like a good idea to me. I don't know if the engine/trans swap was done using the JTR mounts or not. I do know that the wire harness is cooked from the passenger side exhaust. Also the brakes are squishy-thats easy to fix though. I'm gona give a real good look at the engine/trans mounts first and get some pix for yas... Quote Link to comment Share on other sites More sharing options...
COZY Z COLE Posted July 11, 2009 Share Posted July 11, 2009 He just purchased a 1976 280z with a 350/350 automatic swap for 3500.00. the car also came with a 11.9 1/4 mile time slip Hmmmmm..... Let's hear what the mods are to that 350 motor and tranny... LARRY Quote Link to comment Share on other sites More sharing options...
280zex Posted July 13, 2009 Author Share Posted July 13, 2009 as far as I can tell the engine is a 350 cid chevy with camel hump 202 heads full roller motor and timming gears. has a holley 750 double pumper and highrise intake. mallory ignition-dunno if its a uni-lite though. also has a secondary fuel pump coming off a resivoir still using the original pump by the rear tire. came with hoosier 16 x 8 drag slicks and a set of goodyear street tires. has a 3500 rpm stall in the trans. this swap smells of a "shade tree quicky". the motor mounts are nothing more than some channel iron torched to fit. I still gota check the trans mount and driveline. It does have a full dual exhaust but some of the pipe looks like it was crushed to fit ;-( I forgot my camera for pix... Quote Link to comment Share on other sites More sharing options...
