JECS Throttle body sensor? (PICS)
It tells your ECU to shoot more fuel over 4000 RPM. Youre AFM stops reading at a certain RPM [because it is fully open] and TPS is one of the things the ECU uses to shoot fuel.
Read the EFI Bible. It is somewhere here, just do a search.
The zx turbo ecu doesn't use the full throttle switch part.......only the idle switch.
If the distance between the bolt holes is 49mm, then it's off of a VG30 up to around 1989 though the late california Z31s had position sensor harness and switch like the later VG30s and stanza throttle body that used the jecs sensor..
If the distance is around 65mm, then it fits a 280zx turbo and possibly the 280zx n/a.
