fuel feed on a stock tank?
First off
1. Which is the stock feed line on a 260z tank? The top or bottom? I made a mistake of removing feed and return without labeling them.
2. Will the stock feed line be able to pump 110gph? If now how much?
3. For those who used the drain as their feed line what fitting did you guys used? The 3/8 fitting is to big of a tread siZe to fit.
This is for an early 74 260z with a mallory pump for a stock sbf
Thanks
