Stock Z car weights???
RickB
Hey all,
I am entering a race this weekend and they state that the car must weigh " within 150lb's of the OEM weight listed on vehicle"....
Hmm, the only weight listed on the vehicle is the GVRW.
I am looking for some documentation that I can print and carry with me in case they dispute me. They might not enjoy it if I do real well against the predominant Imports...then again they might like it icon_smile.gif
(BTW, My car weighs 2720 w/o driver) 76' 280Z.
FYI
Drag Wars 2
Ultimate Street Car Challenge Quick 16 Rules:
This class is designed for the street racer. NO SLICKS are permitted and no more than one power adder, your full interior must remain...
BODY - Full stock import or compact domestic car or truck body
INTERIOR - full interior
CHASSIS & SUSPENSION - Full stock suspension is required. All components must remain in stock location
WHEELBASE - stock only
ENGINE - Reserved for 4, 6, 8 cylinder and rotaries
POWER ADDERS - One only, no combination such as turbo and nitrous
FUEL - gasoline only, no fuel cells
DRIVETRAIN & TRANSMISSION - FWD, AWD, and RWD entries allowed. OEM transmission and rear end must be used. (hmm...this may be a tough one???)
EXHAUST - Any type of exhaust system permitted (I would have hoped for mufflers??)
TIRES - All entries must run DOT approved street RADIALS, Drag radials are permitted. NO SLICKS OR SLICK TYPE TIRES PERMITTED.
WEIGHTS - Car must weigh within 150 lbs. of OEM weight listed on vehicle.
Guest Night_rider_383
heres the specs on all z models. Scroll down under each model it tells the weight for that model.
Specifications
The 240Z 1970-1973
Engine SOHC Inline-6
Displacement 2393 CC
Compression Ratio 9.0:1
Fuel System Hitachi Twin Side-Draft Carburetors
Horsepower (SAE) 150 BHP @6,000 RPM
Torque 148 FT-Lbs @4,400 RPM
Curb Weight 2355 Lbs
Length 162.8 IN
Wheelbase 90.7 IN
List Price (1970) $3,526
0-60 MPH 7.8 Sec
The 260Z 1974-1975
Displacement 2565 CC
Compression Ratio 8.8:1
Horsepower (SAE) 139 BHP @5,000 RPM
Torque 137 FT-Lbs @4,400 RPM
Curb Weight 2,605 Lbs
Length 164.1 IN
(2+2) 174.2 IN
Wheelbase 90.7 IN
(2+2) 102.6 IN
List Price (1974) $5,750
0-60 MPH 10.0 Sec
The 280Z 1975-1978
Displacement 2754 CC
Fuel System Multi-Point Electronic Fuel Injection
Horsepower (SAE) 149 BHP @5,600 RPM
Torque 163 FT-Lbs @4,400 RPM
Curb Weight 2875 Lbs
Length 173.2 IN
(2+2) 185.4 IN
Wheelbase 90.7 IN
(2+2) 102.6 IN
List Price (1975) $6,284
0-60 MPH 9.4 Sec
280ZX 1979-1983
Displacement 2753 CC
Compression Ratio 8.3:1
(turbo) 7.4:1
Horsepower (SAE) 135 BHP @5,200 RPM
(turbo) 180 BHP @5,600 RPM
Torque 144 FT-Lbs @4,400 RPM
(turbo) 203 FT-Lbs @2,800 RPM
Curb Weight 2,825 Lbs
Length 174.0 IN
(2+2) 181.9 IN
Wheelbase 91.3 IN
(2+2) 99.2 IN
List Price (1974) $9,500
0-60 MPH 9.2 Sec
(turbo) 6.8 Sec
300ZX 1984-1989
Engine SOHC V-6
Displacement 2960 CC
(turbo) 7.8:1
Horsepower (SAE) 160 BHP @5,200 RPM
(turbo) 200 BHP @5,200 RPM
Torque 174 FT-Lbs @4,000 RPM
(turbo) 227 FT-Lbs @3,600 RPM
Curb Weight 3,080 Lbs
Length 170.7 IN
(2+2) 178.5 IN
Wheelbase 91.3 IN
(2+2) 99.2 IN
List Price (1983) $18,699
0-60 MPH 9.2 Sec
(turbo) 7.4 Sec
300ZX 1990-
Engine SOHC V-6
Compression Ratio 10.5:1
(turbo) 8.5:1
Horsepower (SAE) 222 BHP @6,400 RPM
(turbo) 300 BHP @6,400 RPM
Torque 198 FT-Lbs @4,800 RPM
(turbo) 283 FT-Lbs @3,600 RPM
Curb Weight 3,219 Lbs
Length 169.5 IN
(2+2) 178.0 IN
Wheelbase 96.5 IN
(2+2) 101.2 IN
List Price (1989) $27,300
0-60 MPH 7.1 Sec
(turbo) 5.2 Sec
Nice list Night Rider; thanks for going thru the trouble of posting all that info!
RickB, since your tras is OEM, the only "RedFlag" to watch out for are any descriptions w/in the rules that excludes a trans transplanted from one Mfg into Another...AKA: your GM 700 into a Datsun(?).
When is the Import Race...that would be pretty fun to watch a V8Z putting the smack down on the other cars.
If they allow V8's then why wouldnt they allow your 700?
I dont know the rule but to me if they allow V8's then they shouldn't exclude your trans either...good luck.
Kevin,
(Yea,Still an Inliner)
Kevin... No prob bud. That list is something we all can use and i ran across it and trans and rear gear ratio's for the z's the other night so i had it saved to my desktop.
Kevin,
Kevin...not to worry, I called the promoters and I am in!
One prob though (possibly). They are going to allow Mustangs in as domestic compacts??? I could have my hands full with those Vortech 5.0's...hopefully they'll have traction probs (or stay home
Kevin,
BTW, the race is this Saturday...! I'll post to Motorsports...
  • 3 months later...
what were the major factors in the diff. weights.i see that the 240,260,and early 280 z's all had the same wheelbase. was it in the bumpers and sound deadener that was used or is it in other places. how would someone go about getting the weight back down to the lower 2000 lb. range. i'm still a newbie to the sight so any info would help in my selection. i know were there are both a 72 240 and a 77 280. the guy with the 240 wants a lot more than the guy with the 280 so thats why i am so intrested in this.
thanks biohzrd
Guest bang847
when i need my car weight i just put some cardboard in my trunk and head to the paper recyclers. your car weighs in and then it weigh out. and if you bring enough cardboard then they even give you some change. icon_biggrin.gif but thats in downtown Los Angeles.... i know scrap metal facilities have scales too..
The government truck weigh stations around here are usually closed on Sundays, but when they are closed you can still drive over the scale and they put the meter in the window so that the truck drivers can check their weights. Maybe that is a common practice though Canada and the US? My 76 280z was just over 2900 lbs with me in it.
