'74 Dashboard
Does anyone know how to remove the entire dashboard of a 75 260z? i need it removed so i can get the split in it fixed (no i will not just put a cover on it OR buy a plastic dash molding
It is a straightforward removal. Remove the cover at the windshield above the defroster vents. Remove the bolts holding the dash there. Drop the steering wheel , you don't absolutely have to remove it. Unbolt the supports at the console, and remove the console. There might be a couple of bolts on the sides of the dash, I don't remember. Unhook the wiring. I don't know if you have to remove the a/c and heat.
