in need of weber carbs
Guest benthemainman
Guest benthemainman
I am looking for some weber carbs to put on my 71 240z/l28 set up. it currently has 2 su carbs on it and im just wanting to do the dual weber carb setup. does anyone have any suggestions? I am new to this site and just bought the Z about a month ago and am about to start working on it today.
P.S. I am going to keep the l28 setup for now, what would be some good performance upgrades?
thanks.
Which SU mani do you have? You'll have to block off the coolant lines and re-route them if yours go through the carbies. As for the Webers, I'm running a pair of 32/36's and the big problem I'm having is hesitation because of the gooseneck. If at all possible try and get ones with shallow or large diameter goosenecks so you don't get fuel falling out of atomization that I do. I'll go get my jets out here when i do some work here and a bit and tell you what jets I have on them.
