Guest Anonymous Posted January 14, 2002 Share Posted January 14, 2002 The weights were taken with me in it (220 lbs) and with 15 gallons of gas. It weighed in at 3260 total with 1640 on the front tires (50%) . That was 400lbs higher then I was hopping for. I am planning on changing to an aluminum radiator (-20lbs), aluminum motor spacers(-9lbs) , aluminum heads ($$$$$ -49lbs + 75hp), lightweight wheels(-40lbs), fiberglass hood (-30lbs) and remove rear bumper (-40lbs). With a total savings of about 188lbs and about $3000 cost. Of course I can get out and siphon out the gas and drop 325lbs off the total ;however, it is kind of hard to drive like that!! Did I miss anything? Does anyone have experience with a fiberglass rear hatch and front fenders? Quote Link to comment Share on other sites More sharing options...
Tim240z Posted January 14, 2002 Share Posted January 14, 2002 Well....you could always give up the Big Macs and drop some poundage there!! J/K, Tim Quote Link to comment Share on other sites More sharing options...
Kevin Shasteen Posted January 14, 2002 Share Posted January 14, 2002 RickyB Thanks for breaking down the front/rear weights. My 78 2+2 came w/all documents including showroom doc's; of which the car weighed in right at 3000lbs....w/out a driver. Curious Your signature implies a Pontiac 455...is this engine currently in your Z(?). Kevin (Yea,Still an Inliner) Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted January 14, 2002 Share Posted January 14, 2002 A agree with the giving up the Big Macs but boy, aren't they good . I could always changeover to a McRib !! The weights include the 455 and a TH-350 transmission with the battery moved to the rear. Carpet isn't installed yet, nor a radio. Quote Link to comment Share on other sites More sharing options...
johnc Posted January 14, 2002 Share Posted January 14, 2002 A fiberglass rear hatch and a Lexan rear hatch window would save a lot of weight. Some other options: Early Z bumpers Steel headlight buckets Thin wall stainless exhaust system Racing seats No radio No spare tire, jack, lug wrench Tilton starter Keep looking for little things to remove or replace. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted January 14, 2002 Share Posted January 14, 2002 I am going to go with MSA's front and rear kit to do away with the bumpers. I don't have the spare tire anymore (fuel cell). And I have a high Torque MiniStarter, the engine wouldn't turn over with a stock one. Don't you mean fiberglass headlight bucket? What are the cons for a fiberglass rear hatch? I have to have my toons, and if I go to racing seats it will kill the sleeper image. Quote Link to comment Share on other sites More sharing options...
Guest Tom Scala Posted January 14, 2002 Share Posted January 14, 2002 Your my new hero! My favorite motor(Pontiac 455) in a Z. Who needs high rpm engines when you can have 500+ ft.lbs. right off idle. The Edelbrock heads will give you big HP numbers to go with the low end torque. You should post those pics on the performanceyears.com website and give Goatman a coronary Quote Link to comment Share on other sites More sharing options...
Guest 400 ci 280z Posted January 15, 2002 Share Posted January 15, 2002 i know this doesnt have anything to do with the subject but i have a pontiac 400 and are the 6x heads better than the other heads you can put on these. i dont want to go with aftermarket yet because of money. Quote Link to comment Share on other sites More sharing options...
Guest Tom Scala Posted January 15, 2002 Share Posted January 15, 2002 There are 2 different 6X heads. One has a small "4" cast on a flat pad under the valve cover. These were used on mid to late 70's 350 and some 400 TA motors and had 93cc chambers. They will give near 9to1 CR on a 400 with flat tops. The other has either a 6 or 8 cast in the same place and has a 101cc chamber for a CR in the low 8's. Both have 2.11" intake and 1.66" exhaust valves,screw in rocker studs and are good flowing heads for a street/strip motor. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted January 15, 2002 Share Posted January 15, 2002 I am using ported 6x heads from a 400 on the 455. They do give good compression with my trw flattops and a 0" deck. I had to clearance them to work with the Harland Sharp 1.65:1 rockers. But, darn they are heavy! I have a set of #72 heads which are one of the smaller head designs for a 400. If you are close, I can make them cheep. I am with you on loving low end torque. Too bad I don't have the trackion yet. First and second gear are useless due to tirespin. Quote Link to comment Share on other sites More sharing options...
Guest 400 ci 280z Posted January 15, 2002 Share Posted January 15, 2002 i live in okla so it isnt that close. also what is a good cam to use with the 400? i am going to put a edel. performer manifold with it. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted January 15, 2002 Share Posted January 15, 2002 I would call Bruce Fulper at Rock N Roll Engineering (http://www.pontiacpower.com). He can recomend a grind for your engine configuration. Quote Link to comment Share on other sites More sharing options...
