auto/ 5sp l28et differences?
BenLT
Im looking in to buying a donor 280zx that is automatic.
What other differences are there from the 5sp counter part?
The ecu will be different, will the wiring on the motor it self be a little off?
I dont want too many surprises.
Thanks,
Ps:i did search all i found about was the mechanical aspect of the auto / manual swap.
yeah most were auto.
I have an Auto running a 300zxt Manual ECU and dont notice anything really so. Couldnt help ya there. I know the bellhousing bolts the same as I have a 5speed manual as well the only thing I would imgaine would be different would be the Vacuum line that goes to the Auto transmission.
other than that it all looks the same and I have taken parts from my 5sped and they fit perfect on the auto
I pulled mine from and auto and run a 5 speed.
I have no problems with the ECU. The only real difference is it came with and oil cooler and theres a spacer plate on the end of your crank, make sure to take that off.
