MAF Sensor Connector Question
Phillip
So on my 1978 280z I was trying to resolder the wires into the connector for the MAF Sensor, and well the connector chipped away (not too bad probably still could have worked) then it was left right in front of the cowl panel and the hood crushed it.
I need to know if there is anywhere I can buy the connector it's the ones that are on the EFI Harness, believe the same ones that plug into the fuel injectors, Or if the connector from a 280zx would fit? If pictures are needed I can get some, I was unable to find a thread to directly answer my question if this has been posted before, sry I was unable to find it.
