TEC II MAPS> Wanted
sweetleaf
If anybody using the Electromotive TECII with WinTec2 on an L28ET. Please post your maps. I had mine setup great but was running the old PAFZ2 software. Now that I put in wintec everything works great as the software/hardware. but there's something funky about my map. I used the tuning wizard and then blended in some things from my old maps. I would just like to compare with what other people are using. Thanks.
BTW. My current setup is
Electromotive TEC II w/wintecII
T3/T04E
Turbonetics Delgate
HKS bypass
485CC Injectors.
Massive FMIC
2.5" IC pipes
3" Mandrel bent exhaust
Stock Turbo Block w/P90
New Fuel Sys. Kinsler Pump 8AN lines.
240SX TB Everything port matched.
Still need maps. Have a different question. Got the tune running ok. Seems pretty good in open loop. The wideband seems to read properly but as soon as it warms up. The o2 starts freaking out. Bouncing rapidly from 0-5V consistently . The strange part is, if I switch it to open loop mode it reads perfectly. Any ideas? Thanks.
  • 2 years later...
Did you get it working? I'm looking for some base maps as well.
