73 240z suspension help
are there any dimensions out there for the top of the rear strut tower? i'm welding in my camber plates and need to make sure the strut tops are in the correct location. if someone has stock suspension setup...if you wouldn't mind running a string between the 2 strut tops, and then measuring the distance from the front of the strut tower, driver facing, to the string.
i basically want to find out A
