Replacing piston rings with the engine in the vehicle L series FAQ
Phlebmaster
I did this to my L16 in a 1973 Datsun 620 truck when my bottom end would give no more and I was in a pinch. Not the recommended way to replace the rings.....but when you have no other choice. :mrgreen: (my first engine rebuild btw)
I did not pull the motor, So the tools I used were:
4" cylinder honing tool
Sockets: 3/8"= 19mm, 17mm, 14mm, 12mm, 10mm, 10mm allen socket for the head bolts, swivel socket, 3" extension & 5" extension, spark plug socket.
Torque wrench 3/8" (long handle click stop)
Standard 3/8" ratchet (you all have seen these)
Piston ring compressor 4"-7"
Pully puller (for the main pully)
Tie rod separator (for removing the steering tie rod)
Piston ring plyers (I never figured out how to use this one) :lol:
Screwdrivers, flat and phillips 4" & 6"
Scraper for getting the old gaskets off.
Plastigage
Feeler guage for measuring end gap and ring clearance.
Micrometer for measuring tolerances.
I think that was it....I may have used a couple of other common tools.
I also purchased a engine gasket kit with everything. It was better than not having what I needed.
I used the Permatex spray copper gasket stuff as well as the ultra copper and ultra black gasket makers.
Piston rings and rod bearings.
I purchased standard size rings and bearings. But that was because I measured the cylinder walls, pistons, and crankshaft journals for tolerance.
Lucas oil stabilizer and assembly lube.
Quakerstate with slick 50.
New oil filter and fuel filter.
Get a compression tester to check compression before you start and after you complete the rebuild to make sure everything is good.
I did most of my shopping for parts on Rockauto and tools I got from Harbor Freight Tools. The total cost for me was around $225.00 for everything...including the beer. lol
I had her finished in 10 hours including breaks. I hope this helps someone else.
