Camaro T5 stuck in 4th gear
Miles
Application: 350 SBC and Camaro T5 transmission with Hurst shifter
in 72 240Z. Used Dexron fluid in the transmission
500 miles on new SBC and rebuilt Camaro transmission
Up until today transmission shifted perfectly
Problem: After coming to a stop the transmission locks up in 4th gear. It has to be forced out of 4th gear into neutral and it grinds doing this. Sitting and idling in neutral and attempting to shift into 4th grinds the gears. All other gears are perfect. Nothing is binding the shifter.
I am going to check the shifter now.
Thanks
Miles
I replaced the Hurst shifter with the stock Camaro shifter and it shifts pefectly. I'll drive it this way for awhile to see if it locks up again.
Anyone have problems with the Hurst shifter?
Thanks
Miles
I found the source of the problem. There is a stop adjustment on the front and rear sides of the Hurst T5 shifter body to prevent over-shifting. The rear aduster had backed out and was allowing the the shifter to go too far aft when shifting into 4th gear. All is well now.
