aceofspades Posted August 20, 2009 Share Posted August 20, 2009 ok I tried a search on google and here and only found info on 5 speeds and the speedo gears! so its seem the trans in early 260 is not stock seeing the trans neutral switch has different plugs on it! So how do you ID which year your trans is car? is there cast number or stamped numbers in it some where? am i missing it due to dirt? I know it has the yellow speedo gear in it but my speedo is off a bit! also whats the point of the neutral switch on a manual trans? Quote Link to comment Share on other sites More sharing options...
aceofspades Posted August 20, 2009 Author Share Posted August 20, 2009 Quote Link to comment Share on other sites More sharing options...
Xnke Posted August 25, 2009 Share Posted August 25, 2009 that's just a regular replacement switch, it's very likely a stock trans. Quote Link to comment Share on other sites More sharing options...
jbk240z Posted August 25, 2009 Share Posted August 25, 2009 IIRC, the numbers you need to ID the trans are on the top of the bellhousing at the engine block mating surface. You probably could see them from under the hood. Good luck. Quote Link to comment Share on other sites More sharing options...
aceofspades Posted August 25, 2009 Author Share Posted August 25, 2009 number on the top of the trans reads 7322176 Quote Link to comment Share on other sites More sharing options...
