Hot fuse box!!
Mike C
I started replying into the como switch post, but figured this needed a new topic.
Scottie, How did you solve your wiring woes? I have had trouble with my lights and the fuses are getting hot. (Not insulating melting, but hot.) The taillight circuit was the worst. If I remember my basic physics, the heat is at the source of resistance, so I pulled the connector wires from the box and soldered the fuse clips to the wires and rivets. This made a HUGE difference, but not 100% Has anybody else tried this? Any flux you recommend for cleaning brass, including between the rivet and plates? I was mostly happy with the results of the first one and will repeat on my headlight circuit. Just wondering if anybody else has found a solution other than rewiring the car.
