Rear End
borini63
yes. only problem might be matching up the driveshaft flange. they should both be r200 diffys. if one is cv half shaft and the other is universal then you need to swap half shafts or hubs. if one is an r180 and the other is r200 then half shafts have to go with the diffy as the r180 is skosh narrower.
