Heading to the Parts Store, suggestions?
naviathan
Ok, I'm getting ready to finish some things up on my 81. I'm picking up plugs, wires, oil, battery etc... I have a new MSA Stage 4 cam in it and MS-II. What should I get oil wise for this new cam so I don't tear it up while trying to get the MS to crank and run for a bit? I know newer oils are a bad idea because of the lack of zddp. I've heard someone mention using non detergent oil for a first run with a new cam and I've heard some suggest using diesel oil instead and there's also the STP additive for regular oil that increases the zinc phosphates for better wear protection...I've done a lot of reading, but I want to get it right.
Engine setup:
MSA Stage 4 cam
E88 head
F54 block
stock flattop bottom end
2mm MLS head gasket
360cc injectors
Pallnet fuel rail
MS-II ECU
Try to find the oil without the energy conservation tag on the seal.
These oils are of the older generation.
There is some write ups on cam break-in, in lue of the oil problems of today, I'm not sure if they apply, as much.
Don't go on just what I say, search this one, I don't want to be wrong in ANY way.
Posting in the l6 sub fourm would yeild better results, me thinks. ;)
