RUZN Posted September 11, 2009 Share Posted September 11, 2009 OK so I am trying to figure out why I seem to be stumbling off the line every so often with rich black clouds of fuel out the back end. I took apart my distributor and took my NA Z31 distrubutor and replaced the inner electronic thingy. Started up fine and got a good idle and not so much bog. then I went around town everything seemed good. but after I left parts store it seemed like im running on 5 cylinders.. Dose anyone know if the distrubutor internals on a Z31 NA should still advance timing on a 280zxt. I figured the ECU controls advance dose it not? I did turn up the fuel pressure to 60spi for about 5 seconds and then back down to 36ish as I was adjusting it so I pulled plugs and of course they are blackend so I figured i prolly fouled em and with the short drive they just got a bit to sooted. Gonna clean them up and try again. Also from an old post bernarrd said I can just disconnect my O2 but I did that and it runs really rich obviously. SO with my 300zxt ECU swap I have always had a rich start and horrible gas milage but I have been running stock O2 the entire time so should I convert it to the 300zxt O2 will this fix my bad gas milage and poor stumbling starts . Cause I think I have done just about everything at this point Changed parts: Tps temp sensors thermostat oil changed coolant hosing replaced stock fan with electric used manual FPR and stock FPR plugs Wastegates only thing I havent swapped is MAF and ECU MAF dosent seem to do anything when you turn the dial could it be pooched? and causing all these issues... but then would it run fine on highway and around town if MAF was pooched....... I have a NA 300zx MAF from my 300zx so should I try swapping those? any ideas peoples... Removed all idle control stuff I use idle screw now from 240sx throttle body plugged off EGR and anythign else I didnt need according to afshins post about the 300zxt ECU swap only thing I havent done according to swap was the O2 Quote Link to comment Share on other sites More sharing options...
SHADY280 Posted September 16, 2009 Share Posted September 16, 2009 id test your maf, there should be specs on voltage and which pins to test when. my wifes xterra had simmilar issues and it was maf. the ecu didnt even set a code either, so i had to test each part. i thought it was going to be dizzy as well. Quote Link to comment Share on other sites More sharing options...
RUZN Posted September 17, 2009 Author Share Posted September 17, 2009 IT WAS THE FREAKING MAF!!!!!! gawd... hours and hours of testing probing and I thought readings were good from MAF so must have been intermittant cause it only happened every so often GRRRRR.. Now she HAULS!!!! Quote Link to comment Share on other sites More sharing options...
RUZN Posted September 17, 2009 Author Share Posted September 17, 2009 Oh you can use Z31 or VG30E distributor inernals as I have now found out. So instead of that old clear selant hockey puck thing with resistors and diodes on it. You can use the Nice black plastic clean looking doohicky inside your S130T distributor housing. Quote Link to comment Share on other sites More sharing options...
evildky Posted September 17, 2009 Share Posted September 17, 2009 the optical sensors and wiring are the same form the Z31 to the S130, the only difference internally is the shutter wheel, the Z31 has that one larger window otherwise they are the same,, even the plugs at the bottom of the distributor are the same Quote Link to comment Share on other sites More sharing options...
SHADY280 Posted September 17, 2009 Share Posted September 17, 2009 ha!!! good the hear you got it fixed. good thing dumb mechanics like me are around lol Quote Link to comment Share on other sites More sharing options...
RUZN Posted September 17, 2009 Author Share Posted September 17, 2009 Yeah im a 2nd Year here in Calgary so still learning about this stuff!! LOL.. Thing is it was intermittant and really only happened under Load so its kinda hard to Test it with a Ohm or volt meter while the car is trying to tear away from the blocks LOL... It read ok when testing so I guess it must have some faulty wiring internally that gets bumpped around or what not! All I know is its freaking Awesome now! And $20 bucks 94octane atually gets me like 200km instead of 100km LOL So im HAPPY! plus replacing old coil and stuff really made a huge difference Its like a friggin new car. FUN FUN FUN Quote Link to comment Share on other sites More sharing options...
