Injector Questions
  • Administrators
hello hybridz, I got some questions about bigger injectors for an N/A 280z with OEM fuel injection, what is the biggest you can go and what would the difference really be?
Why do you want want to change to a bigger injector with the stock N/A EFI?
You can use any size you want, but trust me on this, you don't want to use any injector other than stock with the stock L-28 N/A EFI! Any size other than stock and you wont be abel to get the engine run correctly!
The stock size injectors are more than adequate for any amount of mods that can be done to the engine with the stock EFI and still retain drivability, performance etc.
