Looking for Speedo Gear for 5spd
Daphur280
Yeah you match the gear to the rear end ratio. If its a stock 240z rear end you probably have 3:36 or somewhere in that ball park. Take the speedo gear from the 4 speed you removed and install it on the 5 speed.
Here are the speedo gears and corresponding rear ratio's
YELLOW is the 16 tooth for the 3.36
BLACK is the 17 tooth for the 3.54
BLUE is the 18 tooth for the 3.70
WHITE is the 19 tooth for the 3.90
RED is the 20 tooth for the 4.11
PURPLE is the 21 tooth for the 4.38
  • 3 months later...
