Installing a shift light
Guest Zpeed
Guest Zpeed
Hey guys
I've just got a Razo shift up indicator, with shift light from a friend who got it from a jap import, and therefore doesn't have the manual to install the thing
it has 3 wires coming out of it... 1 thin red, 1 thin black, and one thick black...
i was thinking, red to positive, thin black to negative, and thick black to coil ...
would that sound right, or not... anyone got any ideas...
when i open up the casing,.. the red wire says +B on the circuit board, the thick black wire says GND, and the thin black wire has IG...
now i'm confused which one is the earth/ground...
The +B is battery positive terminal, the GND is ground. I assume that IG is ignition (switch)controlled power. The first two are common circuitboard designations.
