Project Z Posted September 23, 2009 Share Posted September 23, 2009 My search had gone dry on this so I was wondering if anyone can answer my question. Has anyone used the Apexi Multichecker on their L28ET? I plan to use this but wanted to see other users input as well. Quote Link to comment Share on other sites More sharing options...
Project Z Posted September 23, 2009 Author Share Posted September 23, 2009 Has anyone tried this? I could really use someone's input. Quote Link to comment Share on other sites More sharing options...
hoov100 Posted September 23, 2009 Share Posted September 23, 2009 If you want to be able to check and adjust your EFI system, go with a z31 EFI swap or go stand alone. (the l28et ECU also has no data port, nor can it be tuned.) (pre obd-1) (a.k.a dinosaur) Quote Link to comment Share on other sites More sharing options...
Project Z Posted September 23, 2009 Author Share Posted September 23, 2009 If you want to be able to check and adjust your EFI system, go with a z31 EFI swap or go stand alone. (the l28et ECU also has no data port, nor can it be tuned.) (pre obd-1) (a.k.a dinosaur) Finally! Well I'm not using a standalone, all I'm using is a piggyback (Greddy E-Manage Ultimate). I figured this would be a good tool and looking at the wiring, it's more like I'm just tapping all the signals but I wasn't sure if it'll work. Oh well, back to the drawing board... and Thank you! Quote Link to comment Share on other sites More sharing options...
