AutoZone Moly EP grease for cam break-in?
ANY MOLY grease will sure be better than just oil alone or oil with EOS alone, but the moly cam lubes designed for break-in are supposed to have slightly more MOLY,and are designed, to wash off slowly and yes IVE used MOLY axle grease with great results a few times in the past when I was about 20,and had zero problems, but ID rather recommend use of the correct assembly lube BECAUSE its designed to dissolve in the oil and have a minimal effect on clogging the oil filter which the moly axle grease IS not designed to do, remember you'll want to replace the oil and filter after about 1-3 hours run time, to remove the moly and any metallic crud in the oil from the lifters laping in
http://forum.grumpysperformance.com/viewtopic.php?f=52&t=282
http://forum.grumpysperformance.com/viewtopic.php?f=52&t=2166
http://forum.grumpysperformance.com/viewtopic.php?f=52&t=1489
http://forum.grumpysperformance.com/viewtopic.php?f=52&t=130
Edited by grumpyvette
