motor pics.
here are some pic of the 305 small block bored 30+I have. The motor is out of a 78 buick regal with a 30 272 cam 10 10 crank msd ign 350 turbo tranny and a stage 2 shift kit. still getting more histopry on the motor and it's spec. Such as compression, I forgot whay type carbuerator.....
Edited by 2fst4u
adding info
Here are some just pics i took .....
Currently the car is gutted. I plan on trying to cut out as much rust as possble and then replace it as usual, but with a twist. After replacing all the floorboards, I plan on taking some polished diamond plate and cutting out the "Z" logo and placing the the diamond plate ontop of the floorboard. The idea is in my head and not yet on paper. For the motor I hace a smooth idea of pulling it, lowering the compression and putting an a stage 1 turbo kit from wrench rat racing. With all parts being replaced of course. As for the hood. I have a fetish with carbon fiber. I think that is all that needs to be said. As for the interior, metal, with diamond plate floorboards, metal sides and such, replacing the seats with "highend" perfromance seats, custom made. as fopr the rear hatch. Since that car has a nice slope the it i plan on welding a flat deck to it in such that it will hold a voltex custom carbon fiber wing. Again plans are in my head and not on paper yet. As for the color . maybe that stock blue with a little pearl.
But as for now need to remove as much rust as possible and get the thing primered. I will post pics as progressis shown. i am looking foward to the help and advice from the forum as this happens, and if anybody is close enough to ventura let me know and we can get down on this car thing together. Always many hands make lite work.
Try reaching to the rear strut bolts. Having it bolted to the floor like that will result in you compressing your spine in a crash. Just look at the physics of it...when you crash (head on), your body wants to pull forwards. Your belt is then pulled forward and it wants to pull more material; it can only get that by going downwards. I probably didn't explain that the best, but just give it a sec and think about it.
Ok brain fart. we are talking about the racing harness..... not the harness i found under the passenger seats. yes the harness is being moved to the bolts in the rear. So i fully understand what was said before. The harness bolting points will change....
Good looking out thought.... Thank you.
Thank you braap. I have also started a thread in the non tech section. but i has come to my atention that is has already been brougt up and rejected. But if you could take a look at it and give me your advice. I do believe it would help out alot. If anything at least a member info section possibly. broken down by area location and such liek a directory.
