L28ET Head Gasket
jacob80
  • 3 weeks later...
put a straight edge across your manifolds.usually the exhaust has to be milled to be flat again.if the engine was built correctly(all machined surfaces checked flat) the brand of head gaskit shouldnt be a problem.if you try to save money by not having machining done you will kick your self later.
