Guest 06goat Posted October 14, 2009 Share Posted October 14, 2009 i have a 2006 gto 6L with the ls2 t56 i had recently blew it out and im looking to buy another transmission would a ls1 t56 bolt up? would i need a ls1 clutch and flywheel? any little info helps thanks Quote Link to comment Share on other sites More sharing options...
77turboz Posted October 14, 2009 Share Posted October 14, 2009 as far as I know, the ls2 t56 is identical to the ls1 t56. I know the bolt pattern is the same, the only thing that might be different is the tail section or the release bearing, but Im sure those could be swapped out from yours and reuse or replaced with new. Quote Link to comment Share on other sites More sharing options...
