240z vs 280zx rotors...are they different?
I found a great deal on a set of drilled and slotted rotors but the set is for a 280zx. I found them because I was looking for the zx rear rotors for a disc brake swap in the back. I feel like I can't let this deal escape me. That being said, what's the difference between the front rotors on a 240z and a 280zx? are they different diameters? thickness? What if I used front calipers from a 280zx too?
sorry if this is answered a lot, I did search but I couldn't find anything.
so they're wider I'm guessing, that would be because they are vented right? larger diameter vented rotors from a 300zx have been used right? what's to stop these from working? if I get calipers wide enough (meant for vented rotors) and find a way to mount them then it would be a similar idea to the 300zx rotor/Toyota 4x4 caliper swap
They are wider, but they're smaller diameter. They're 10.5" so you'd have some serious issues with bolting up a caliper. If you want a cheap brake upgrade the 300ZX is a little easier because the rotor diameter is the same as the Z at 11". That simplifies things a lot.
