az240z Posted October 22, 2009 Share Posted October 22, 2009 I have done some searchin but could use some help. There used to be a place where you could put in an auto tranny tag ID and get info on the tranny. Does anyone know where I can do this. I have one that supposed to be out of a 240z with the tag, JAT model x2770. Need to find out if this is in fact a 3N71B tranny. Thanks in advance for your help. Quote Link to comment Share on other sites More sharing options...
GrayZee Posted October 22, 2009 Share Posted October 22, 2009 I don't know where the markings are but I believe the Hayne's service manuals used to tell you where to find the numbers near the front of the book. Assuming it IS from a 240z it SHOULD be a 3n71b Quote Link to comment Share on other sites More sharing options...
Warren Posted October 22, 2009 Share Posted October 22, 2009 The x2770 is a JATCO 3N71B 3 speed auto tranny for a TURBO turbo car. The Non-Turbo designator is X2707. The X8703 was a 3 speed with with a lock up converter. ALL are 3N71B's. Refer to the 82 S130 microfiche for more info or verification. Quote Link to comment Share on other sites More sharing options...
HowlerMonkey Posted October 28, 2009 Share Posted October 28, 2009 You might also check for a white dot on the modulator. White dot usually means turbo tranny but some have been replaced by now that might not have the dot. Also...the 280zx turbo 3n71b has a larger diameter output shaft.........but the outside diameter of the yoke that goes into the tailshaft housing is the same as in non-turbos.....just a bigger hole. Quote Link to comment Share on other sites More sharing options...
