Rod in NC Posted October 26, 2009 Share Posted October 26, 2009 Hi guys....I think I have the wrong collector flange setup on my Sanderson header-to-exhaust pipe connection. Attached is the pic from the JTR website showing the blockhugger headers that I have. The three-hole flange plate is loose and can be spun around the flared port. I guess I have never seen one of these types, and am just used to seeing a flat triangular flange to mount to. Question: Can I bolt up a standard flat 3-hole flange with a standard flat gasket to this header, or will that leak? I'm building my own exhaust for the car, and need to make sure I use the correct mating flange on my header pipe. The more I look at this, I think I might need a donut-type gasket and a flared pipe on the mating header pipe to mount to the header. Right now I just have a standard 3-hole flat plate welded to my header pipe which I was going to mount to the header flange. Any clarification would be helpful. Thanks. -Rod Quote Link to comment Share on other sites More sharing options...
Administrators BRAAP Posted October 26, 2009 Administrators Share Posted October 26, 2009 The three-hole flange plate is loose and can be spun around the flared port. I guess I have never seen one of these types, and am just used to seeing a flat triangular flange to mount to. That design allows the installer to "clock" the bolts in a position that is easiest to access in the vehicle. The exhaust shop mating up your exhaust to the headers will build the header pipe similarly with a flat flange and a floating 3 bolt flange ring and sandwich a gasket similar to what is pictured below in between the flat flanges. Courtesy of frsport.com Quote Link to comment Share on other sites More sharing options...
bschiltz Posted October 26, 2009 Share Posted October 26, 2009 I used a high-temp RVT instead of the gasket and it seems to work pretty well. Quote Link to comment Share on other sites More sharing options...
