atrain Posted October 26, 2009 Share Posted October 26, 2009 so my volt meter was starting to look like my tac ( revving up every time I revved the engine) So I figured the voltage regulator was having issues. I unplugged it and the car now runs fine. The Battery is nether over charging or dieing. It also idles a little higher. any reason I should get a new one? I am sure there must be. Or should I just run the l28 without a voltage regulator?Thanks! p.s. It was kind of fun having my volt meter in the red as my gauges and headlights where super bright and my wiper where ridiculously fast lol. I was sure something was going to catch on fire. Quote Link to comment Share on other sites More sharing options...
darom Posted October 29, 2009 Share Posted October 29, 2009 I had the same problems on my 76 as you did, until I swapped the alternator: http://www.atlanticz.ca/zclub/techtips/alternatorswap/index.html If you have a later model alternator with built-in voltage regulator, then you won't need your stock one. After the upgrade, my voltage gauge is steady, the charging voltage is about 13.8-14V, the lights are brighter etc. I found the 79 alternator at the local junk yard. This fusible link upgrade followed: http://www.atlanticz.ca/zclub/techtips/fusiblelinks/index.html Quote Link to comment Share on other sites More sharing options...
