Making An Evaporator Can
TomoHawk
Is it possible to make something the 280Z's charcoal cannister/evaporator can?
I was thinking about rolling some (fuel-proof) cloth with activated charcoal, then jam it into a short length of 1 1/2" PVC pipe, cap the ends, then attach the plumbing. The cannister that's in there is sooo big and takes up room I could be using for my power steering pump.
That doesn't hit me as something safe to do. It doesn't look like there's enough room in there. If you go down on the wheel, then you end up tearing the thing out. You could move it to the radiator area, but that will be tough to access, but looks like the best place so far, unless you can get a compact version of the thing.
What do cars use today? Is it smaller?
